UWB radar stručnjaka: Ugoditi, trebam vaš savjet ...
B
Breixo
Bok svima,
Ja sam koji su uključeni u jednostavan dizajn UWB radar za otkrivanje kratkog raspona pokreta (manje od 30 m).Želim izbjeći projektiranje antena i Ive 'postaviti usluga koji nudi zakrpa Antene 3,5 - 5,9 GHz, ali u popis programa ne postoji UWB.
Ja popis sažetak antena i preporučuje aplikacije od usluga:
for 802.16e, WiMAX3,5 GHz 8 ili 14 dBi Patch Antennas
za 802.16e, WiMAX
for US Homeland Security & Public Safety Program4,9 GHz 11 dBi Patch Antennas
for 802.11a, WiFi5,3 GHz 8 ili 11 dBi Patch Antennas
za 802.11a, WiFi
for 802.11a, WiFi, RLAN, FWA, WiMAX5,4 GHz 8 ili 11 ili 22 dBi Patch Antennas
za 802.11a, WiFi, RLAN, FWA, WiMAX
for 802.11a, ISM, UNII, WiFi, Mesh Networks5.8 GHz 8 ili 11 ili 19 dBi Patch Antennas
za 802.11a, ISM, UNII, WiFi, mesh mreže
4,4 GHz do 5,5 GHz 8 dBi Broadband Patch Antenna
- Homeland Security- Javna sigurnost Usluge: Vatrogasna, Policija, Security- Rapid Deployment Instalacije- Large Scale WLL- Personal Area Network (PAN)- WLAN / Hot Spot- WLAN / On-Scene Incident Command- 5.3 GHz Band Programi- IEEE 802.11g Wireless LAN- WiFi
5,1 GHz do 5,8 GHz 22 dBi Broadband Patch Antenna
- 5.3 GHz Band Programi- 5.4 GHz Band Programi- Nedopušten European 5,4 GHz Band Programi- IEEE 802.11g Wireless LAN- WiFi Systems- WiMAX Tehnologija- 5.8GHz UNII programi- 5.8GHz ISM programi- 5.8GHz Wireless LAN sustava- 5.8GHz WiFi aplikacija- 5.8 GHz bežični video sustav
5,1 GHz do 5,9 GHz 8 dBi Broadband Patch Antenna
- 5.3 GHz Band Programi- 5.4 GHz Band Programi- Nedopušten European 5,4 GHz Band Programi- IEEE 802.11g Wireless LAN- WiFi Systems- Radio Local Area Networks (RLAN)- Fixed Wireless Access Systems (FWA)- WiMAX Tehnologija- 5.8GHz UNII programi- 5.8GHz ISM programi- 5.8GHz Wireless LAN sustava- 5.8GHz WiFi aplikacija- 5.8 GHz bežični video sustav
5,4 GHz do 5,8 GHz 19 dBi Broadband Patch Antenna
- 5.4 GHz Band Programi- Nedopušten European 5,4 GHz Band Programi- IEEE 802.11g Wireless LAN- WiFi Systems- Radio Local Area Networks (RLAN)- Fixed Wireless Access Systems (FWA)- WiMAX Tehnologija- 5.8GHz UNII programi- 5.8GHz ISM programi- 5.8GHz Wireless LAN sustava- 5.8 GHz bežični video sustavMoja pitanja su:
a) Mogu li koristiti bilo koji od ovih antena na moj dizajn?
b) ako je prethodno pitanje afirmative, Jesu širokopojasne modeli bolji od onog bend?Thanks in advance,
Ja bih započeti definiranjem zahtjeva za antene
centar frekvencija
pojasna širina
dobitak
SLL
S11
veličina
kapacitet snage (može biti problem s redar)
sažetak sadržaja
itd.Sa tih parametara u ruci to onda ima smisla gledati na anyennas te liste kako bi vidjeli ako su neki od njih korisna.Samo upozorenje patch antena ne općenito posebno širokopojasnog i da će često ne rade dobro na UWB primjene.Postoje iznimke.
Hi Azulykit,
Hvala Vam na brz odgovor.Pa, ja ne znam neke od vaših pitanja, ali mi treba da radi neki prototip de metara, nakon što je, ja ću tražiti dobrog nastupa.
Quote:
centar frekvencija:
<img src="http://www.edaboard.com/images/smiles/icon_cry.gif" alt="Crying or Very sad" border="0" />
Mmmmmm, hi momački, Stvarno nema UWB stručnjaka na ovom forumu?
Ugoditi, trebam tvoj savjet!
Patch antena uski bend i neće proći UWB impulse.Te će se zaglavi sa wideband antenom kao što je rog (medium gain) sami ili rog prehrana parabolični reflektor (visoka dobit) ili equalangular spiralu (low gain).
Na niže frekvencije vam svibanj biti u mogućnosti koristiti zapisnik periodičke antene.
Hvala, nadut,
at a center frequency of 4.95, I will have a bandwidth of 1.1 GHz that I think is enough for an UWB Radar application.
Ukoliko vidite moje prethodne liste mogućih kandidata antena, postoje neki koji su calified kao "širokopojasni", tako, na primjer, da li koristim 4,4 GHz do 5,5 GHz 8 dBi Broadband antena
u centru frekvenciji od 4,95, ja će imati propusnost od 1,1 GHz mislim da je dovoljno za UWB primjene Radar.
Taj 'pravo?
Morate koristiti antenu nekoliko oktava širok za najbolje rezultate.Antena ste identificirali će biti dobar prvi probati dok ste identificira širu propusnost one.Jedan kriterij je točnost udaljenost vam je potrebno.
Općenito, inverzna bandwith će vam ograničava rezoluciju vrijeme.Vaša elektronika svibanj isto tako biti ograničenje rezolucije vrijeme.
Antena svibanj dobro raditi u svom bendu.Molimo provjerite BMS web stranicama, oni se prodaju takve antene.
Srdačan pozdrav
Breixo wrote:
Hvala, nadut,at a center frequency of 4.95, I will have a bandwidth of 1.1 GHz that I think is enough for an UWB Radar application.
u centru frekvenciji od 4,95, ja će imati propusnost od 1,1 GHz mislim da je dovoljno za UWB primjene Radar.Taj 'pravo?
Quote:
Hvala, nadut,Ukoliko vidite moje prethodne liste mogućih kandidata antena, postoje neki koji su calified kao "širokopojasni", tako, na primjer, da li koristim 4,4 GHz do 5,5 GHz 8 dBi Broadband antena u centru frekvenciji od 4,95, ja će imati propusnost od 1,1 GHz mislim da je dovoljno za UWB primjene Radar.
Taj 'pravo?
Za radar aplikacija kao što je to moja prva misao bi bilo isprobati jednu od varijacija eksponencijalna utor.Look up Vivaldi antena.Oni su nešto direktivi, relativno lako izgraditi i može pokrivati nekoliko oktava, tako bandwith obično nije problem.
Eksponencijalne rog antena također su uobičajene i bandwidths od 2 do 18 GHz.ETS / Lundgren ima na raspolaganju a tu su i drugi izvori za slične antene.Predvidjeti dobit na 10 do 12 dBi raspon i antena koja ima oko 5 otvoru "od 7", a oko 9 "duga. To je još jedan dobar izbor i to može biti kupljen. Instant zadovoljenje. To ne dobiti bolje od toga. Ova rog je vjerojatno čak i bolje nego eksponencijalna utor kao rješenje.
Ne vidim problem s vlasti razinama te citirati.Vi ste vjerojatno da će izazvati ove antene tugu.Rog i Vivaldija također nemaju potencijal za grupno kašnjenje probleme koji vam svibanj vidjeti u drugim više konvencionalne širokopojasne antene.Nemam direktno iskustvo s LPD u ultra wideband radar kontekstu (sam ih koristi drugdje intenzivno) ali sam redovito vidjeti upozorenje u literaturi da oni mogu biti prilično disperzija.
Ako idete u FCC part 15 Pododjeljak F stvari provjerite da li se gleda na sekcije koje se odnose na radar aplikacija.
Druga misao, ako s obzirom na niz temelji rješenje bih pogledati strukturu hrane pažljivo kako bi bili sigurni da je korporacija, a ne serije feed.Formiranje snopa mora biti vrijeme kašnjenja temelji nego faza odlaganja temelji.Pogledajte na 18 dBi patch polje vas navode kao kandidat u tom kontekstu.
Za UWB primjene
Vidio sam ljude pomoću piramidalne HORN, ROD antene.
Frekvencija je 5.8GHz su koristili, jer to dolazi u ISM band.
U mogu pronaći tutorijali i dizajn programa za rog na ovom forumu.
AbhishekabsDodano nakon 5 minuta:U 5.8GHz band / - 75 MHz pomak je dozvoljeno.
